Tightening or replacing the screws that hold the companionway hinges on the 310
Catalina 310 77 Atlantic Highlands NJ NJ
I noticed that the hinges on the Cabin sole that support the companion way steps are loose and need to be replaced. I do not want to just put in larger screws, because that never lasts. What I want to do is put new screws in and secure them under the sole with lock washers and nuts. My problem is how to access those screws. Has anyone done this and how did you do it?
Thanks in advance
Jack
Jack, give @LeslieTroyer a PM shout. He just redid his Catalina 36 sole and may have an idea that will help you.
Nov 18, 2010
2,441
Catalina 310 Hingham, MA
Jack,
I had no luck trying to do the same. So I over drilled the area and filled it with Six10. After it was setup I drilled and tapped it and put machine screws in that were about 2 inches long. I also went back to using the strap from the bulkhead.
Good luck
Likes: Alansails
May 20, 2016
3,015
Look at rivnuts. When you get the right grip length they really hold. I use Stainless on sole screws that failed and they really hold. They are like pop-rivets but the center is threaded
Les
leo310
Dec 15, 2006
651
Catalina 310 44 Campbell River BC
Had the same problem. What I did was drill a larger hole glued in a hard wood pug and screwed the hinges back inplace
Likes: DaveJ
Thanks everyone. I like the idea about filling the holes, then re drill.
