The cap shrouds on our 2014 Oceanis 37 are very loose above the lower spreaders. The section below the spreaders seems adequately tight. Looking from the deck I don't see a separate turnbuckle above the spreaders for the upper portion. The lower section has a turnbuckle at the bottom, and goes up to the spreader. From that point on the spreader there is an intermediate shroud (with turnbuckle), and the upper cap shroud going to the upper spreader and mast head. When I tug on the lower part of the cap shroud, it does not seem to affect the upper part, so I don't think simply tightening the lower turnbuckle will tighten the upper part. Does anyone know how I can get the upper part of the cap shroud tighter?
P.S. Bonus points for solutions that don't require going up the mast.
