Tidal Grid
MarkieMark
Hello All, just bought a 76 22 Oday. I am thinking of using the tidal grid at the marina. Any issues I should know about, ie will the keel support the boat ok.
Thanks
Jan 24, 2005
4,881
Oday 222 Dighton, Ma.
Markie,
I've never heard the term "Tidal Grid" used before, but I surmise that you're referring to a shallow slip area. I'm pretty sure that the O'Day keel can take the weight of the boat, but if you have bottom paint on your keel, it could wear off with two groundings a day. Then you'll get Barnacles on the bottom of the keel which can slow your boat right down. Also, this boat doesn't have a kick up rudder and you have to take into consideration what might happen if it grounds out. Could it cause damage to the pintles and gudgeons, or even the rudder? Myself Markie, I would rather have a mooring than a slip any day just as long as the marina provides a live dock where I can load up friends and gear. I use a 9' kayak to get out to my mooring. It fits nicely in the bed of my truck under the cap, kitty-cornered. It even stays in my truck all through the winter. I tied a 15 or 20' line to the bow of the kayak and run it behind the lifeline rail and back to a winch when I need to get on and off my 22. I can stand right up in my kayak while holding on to my boat. A mooring is cheaper, and you sail off it or sail to it with a little practice. The kayak can be towed right behind your boat with no drag whatsoever.
Ahoy!
Joe
May 31, 2004
858
Catalina 28 Branford
Tidal Grid?
Not sure what a Tidal Grid is, but if Joe has it right, then I agree with him: the keel on the Oday 22 will easily support the weight of the boat. If your boat will be on the bottom twice a day, you will need to unship the rudder when you are at the mooring; the rudder on the Oday 22 is deeper than the keel. Also, I don't know if the '76 model has a centerboard, but if your boat does, you may likely lose the use of it. Mud or sand will get into the slot every time the tide leaves you on the bottom, clogging it up and preventing the board from moving freely. This site is filled with posts from Oday centerboard boat owners sharing stories and solutions for stuck centerboards. In any case, the 22 is great boat, and you will enjoy her.
MarkieMark
Thanks for the feed back!
Hi Guys, I may have used the wrong term but homer has the right idea. I do have a proper slip for the boat, the tidal grid allows you to place the boat in at high tide and then as the tide goes out the boat ends up on a wooden platform so you can do maintenance etc.
Regards
