If your 27 has gate valves you should replace them with marine bronze ball valves from one of the big Suppliers rather than try to repair them.Got a h27. Still restoring. The waste 1.5" valve is leaking, thus filling the waste water tank. Can it be serviced without removing. It has FAST stamped on the side and is brass I think.
Just finished doing the job on my H27. Not the worse job i ever tackled, but right up there! I agree about the tight space for pipe wrenches. Ended up cutting the old gate valves apart with an angle grinder. Make sure you dry-fit everything first before you drill holes to hold the flange. Btw, if you've got a set of tap & dyes, you can use a large one for the thruhull tool. Saves a few $$. If ya end up cutting them out, you'll probably have to remove the thruhulls and repair the threads.Got a h27. Still restoring. The waste 1.5" valve is leaking, thus filling the waste water tank. Can it be serviced without removing. It has FAST stamped on the side and is brass I think.
Can you see them now?Oh thanks again, Gorilla! Could not see your pics friend.
Wow, I'd take him up in a heartbeat. Find out how he likes his steak, first, though.
This is a vital job, one that will not brook doing it too casually. Take it seriously and get it right. As a pro I have done so many of these replacements that I could probably do it in my pajamas, half asleep, hung over, with one hand tied behind my back, on the phone, while a woman nags me about something. I am not far from you and I tend to work (for members of this site) for a beer and a steak sandwich (no onions). If you need any advice or help with it, you are ever welcome to get in touch.
Thanks for the vote of confidence, Stu! Now I'll owe YOU a beer.Wow, I'd take him up in a heartbeat. Find out how he likes his steak, first, though.![]()
