Jim
New owner of a '73 Dinette model. 8 HP Honda outboard. A lot of good things have already been done to the boat, but overall maint. has been neglected. So some questions Thru hulls are the original pieces of pipe wrapped in FG to stiffen them. The valves have been changed to ball valves, but I'd really like to put seacocks in with my next <first> haul-out at Christmas time. Some recommend making a shaped pad of plywood or phenolic impregnated fiber, others build up a pad of fiberglass. Has anyone used the high density poly like Starboard yet? Suggestions are welcome Winch servicing, boat was retrofitted for Spinnaker and has 2-16 Barents and 4-10's. Does anyone know if the springs and pawls in the Lewmar kit will fit? And the "circlips" on the top, too? Or should I try to get the parts from Australia? I measured the T tracks on the boat, and they come between 7/8" and 1". What was really installed? I won't know what the rudder shaft and bearings are like until I drop the rudder at Christmas. Any suggests about replacement bearings? Installing a zerk fitting for grease? Judy B seems to have no problem with just cutting into the headliner, I'm a little more chicken then that, but I do want to rebed my lifeline stanchions and that seems the only way to get there. Jim, standing in a cold shower, comtemplating tearing up $100 bills
