After crawling in "Overture" for two Saturdays. This is what I have
found. One electrical rats nest, which to explain, if I could, would
take way too long. The thru hulls are a mix of old gate valves and
some brass ball valves. They have some corrosion don't look good. I
found four plus the depth and I assume somewhere the knot meter. This
is what I found and the OD of the stub.
Head Inlet 1 3/4"
Sink 3/4"
Sink drain 1 1/2"
Engine cooling 3/4" (seems small)
Is there anything that I missed and are these sizes correct. When I
pull her out I am planning on replacing them all. Should I increase
the size of any of them? Should I use bronze or plastic?
Thanks to everyone for their help. This board is and will be an
excellent source if information and support.
PaulM
Head Inlet 1 3/4"
Sink 3/4"
Sink drain 1 1/2"
PaulM
