First I want to thank you for the GREAT tutorials!!! I was a sailmaker years ago but never got much experience in the maintenance of keel boats. 4/1/11 is the first haul out for my new to me 78 Cat 27 and I'm trying to get my ducks all lined up.
I am going to install flanged seacocks on the 4 existing thru-hulls. I want to use the alternative method of bolting just through the backing plate. I plan to use 5/8" FRP and wonder if thru-bolting the backing plate versus tapping would work? I could countersink the hull side of the backing plate for the bronze flat head bolt and epoxy the bolt in the hole to keep it from spinning. Any thoughts?
You noted you use 3M filler to fair the outside of thru-hull installation. This seems to be a thickened vinyl ester system and is pretty high priced. What would be the problem with using a thickened epoxy filler instead? The epoxy route seems to be more cost effective and less water permeable.
Thanks
Steve
S/V Judy K II
Thanks
Steve
S/V Judy K II
