I am now ready to install air conditioning in my HUN 310, but when I talked with Hunter Marine about locating the overboard discharge, they told me that the hull is cored above the water line(with balsa wood!) and that I would have to clean out the wood and fill the gap with epoxy before installing the thru-hull fitting. This makes it a little more difficult and more time consuming that just drilling, caulking with 5200 and tightening the backing nut. I would appreciate any advise from anyone with first hand experience on above waterline thru-hulls in late 90s hunters. The boat is in the water so I was planning on tapping into the engine pickup temporarily until haul-out next fall but installing the discharge fitting while in the water. The factory also said that they normally make a small square with solid fiberglass for future A/C installation, but I could not identify such are when looking under the gully cabinets where the factory plan shows the discharge. HELP... *bzzThanks,s/v Calaloo
