Hi Maine,
I was wondering what you opinion is on the best way to seal up a through-hull depth transducer/fishfinder. I'm putting a Ray-B260 on Argyle this year. The last time I messed with below the waterline through-hulls, I used 3M 101 polysuflide to seal it up and that seemed to work great for the application. That stuff doesn't exist anymore, however.
Is there a good alternative to the 101? It seems you like the "Boat-Life" stuff when not using Butyl, topsides. Do they have a product that you use for sealing below the waterline?
In addition to the sealant, I'm curious about how to handle the fairing? The transducer comes with a fairing to help with drag and make installing on a deadrise easier. Do I just use sealant on the fairing just as I wold on the bronze through-hull.
Hull is solid glass, ~20-25 degree deadrise at the install location.
Thanks for any advice
-Argyle
-Argyle
