I am redoing my head and I need to reroute the hose from the macerator to the thru hull which in turn I now need to rotate the bronze elbow on top of the ball valve clockwise 90 degrees. The boat is in the water and the elbow looks like it's been on there for many years, Question is: (1) How do I rotate the elbow without disturbing the thru hull? (2) should I remove the elbow and clean everything and reinstall it? (3) if so, if it "frozen" or "questionably" tight can or should I use some heat to help break it loose? (4) What other options are there besides hauling the boat out?
[/URL][/IMG]
