thru hull plug
10
islander bahama 24 GROTON
I am restoring a 24' sloop. I removed the old toilet and would like to plug up the thru hulls. Rather than grind and fiberglass it closed, is there a plug fitting that would replace the original thru hull? That would be quick and effective it it's available.....steve
Mar 8, 2011
296
Ranger 33 Norfolk
Install a thru-hull like normal and cap it with a bronze pipe cap? They sell the pipe caps. . .maybe go a step further and install a groco flanged base like you normally would and just cap it. I think it would be quicker and less effort than grinding and glassing the hole in. . .and leaves the option of putting a ball valve on in the future if you need too. . .
just my 2 cents ;)
Feb 14, 2013
10
Where would I find a bronze cap for a bronze thru-hull fitting? It is not available through West Marine or Defender or local hardware stores. That is the route I would like to take instead of a grinding/epoxy project. I have 4 holes to cap
ACE Hardware or a good plumbing store. Just get the right threads.
Joe
Jun 1, 2004
8,349
This solution is kind of pricey..... might find a marelon substitute will be more cost effective.
Here's a plug:
You may also may need a hex bushing:
Feb 14, 2013
10
I have been reading about Marelon fittings and I'm impressed. Do they make a cap for their thru-hulls or is there a compatible part I can buy?
Jan 15, 2012
20
Dyer Dhow, Cats Paw 10 ft, 12 ft Montpelier, VT
All Marelon fittings are NPS threads, contrary to their website and catalog. Any cap and plug you're going to find around locally or on the web will probably be NPT.
However, since there is no real structural at play regarding caps and plugs the NPT threads should work fine.
A company near you in Portsmouth RI, Ocean Link (www.oceanlinkinc.com), has plastic plumbing fittings including caps and plugs, made by a company called Bee Valve. They're schedule 80, 30% glass-filled polypropylene and exceed the ABYC materials standard.
