I have a manual billge pump that is not connected to a thru hull fitting. If I want to use iit, I must toss the outlet hose over the side and start to pump. There is an electric bilge pump with a thru hulll on the transom and I was going to attach the two together but was advised that I would need a check valve on the manual side and it would possibly fail at the worst possible time. I would llike to put a thru hull on the port side by the stern but I am not comfortable with drilling through the hull. Does anyone have any advise as to whether or not this is advisable or should I just rely upon tossing the discharge end of the pipe overboard when necessary?
