Thru hull fittings
Jim
How difficult are thru hull fittings to change? My '85 Catalina has originals and one stuck closed. Time to change them. Any suggestions?
H
Hans Mosberg
Ball Valves
My '85 Cat27 has glassed-in, threaded plastic through-hulls, with (plastic) ball valves screwed on top. If a ball valve should lock up, I believe it would be relatively simple to replace - just a matter of disconnecting the hose inside and unscrewing it! I would even do it with the boat in the water, after plugging up the hull opening. Good luck, Hans
L
Leighton
I need to replace some of mine too..
but how do you do this while the boat is in the water? I know it's a dumb question but I have to ask.... Don't really want to wait another year to pull her out to change them as I'm putting on a new bottom paint.
