So at first glance these may seem like a good idea, however in real life are they really worth it? My boat has a few.... one on engine intake and one on a/c intake. At the end of last season I took a few minutes to pull all the debris out that was trapped inside the strainers from under boat. Fast forward.... The past few weekends we have been staying at slip so we can run the heat. Sunday found my heater having troubles and saw interior strainer was full of sea grass... emptied it... all good. However before closing things up I blew into the intake hose and could barely get air through meaning the external strainer was completely blocked. Now what?? I took the hose completely off and found it clear then opened the valve and the water trickled in... obviously blocked. Now if it were a simple skin fitting without a strainer on outside I could have blown and cleared the debris. After finding a solid copper wire and working it down through the 90 degree fitting I managed to get enough grass out to get a steady flow. I am considering removing these as they don't appear to be worth the trouble.... If this were the engine intake I would have to dive down and spend a lot of time under water to fix. Am I missing something?
Thanks
Greg
Thanks
Greg
