Thru-hull discussion - Upgrades and issues
Apr 5, 2009
3,327
@jonelli
I had missed this thread back in Oct so thought not too late to answer your question above.
As for me I did change all of my OEM Marelon ball valves back in 2019. Here's a link to my thread from back then.
Marelon Ball Valve Seacocks
However, after a year those 93 series ball valves stiffened up a bit I got nervous as they seemed to flex a bit. My wife won't even touch them. And then I found another test by @Maine Sail on Marelon Thru Hulls where the mushroom head failed.
Even though I used the flush fit thru hull I decided to improve the thru hulls even more.
Last spring I planned to upgrade further to Series 93 OEM Flanged Seacocks with the Buttress thread thru hull. Note: The buttress thread thru hulls have a much thicker body than the #251 thru hull that failed in the above video.
I special ordered two but they came in too late for me to install. I did find one with a mushroom head on Defender and installed that for a new AC water intake.
That new valve feels so secure I'll replacing the three remaining ball valves with the Series 93 flanged seacocks and thru hulls this spring.
I'll follow @Hayden Watson 's procedure for using the mushroom head thru hulls.
Edit to add: I already have backing plates cut from 1/4" G10 for this job.
That video perfectly illustrates what I was saying about the difference between our OEM ball valves and the new flanged seacocks. Just use something more than Teflon tape along to seal the threads.
Jun 2, 2014
606
Catalina 30 mkII - 1987 Alamitos Bay Marina, LB, CA
@jonelli
@Ward H - I'm a little confused as to what you ended up doing. In the other thread it sounded like you were going to put OEM93 valves on your original thru hulls. Did you end up doing that?
I think I might consider doing that, I'm still on the fence with all of it.
Ward H
Nov 7, 2011
3,842
I don't blame you, I was confused myself. I'll try to explain better.
In 2019 I went back and forth on what I was going to use but ended up with the new 93 Series in line ball valve with the CF250 thru hulls. Those thru hulls are flush fit and fit the recess in the hull very well. The 93 Series in line ball valve is built differently, improved handle, over the 850 valves that came in my C30.
Those CF250 thru hulls are held in place with a large nut. Then the ball valves screwed onto the thru hulls. While they were a huge improvement over the 850 valves, after using them for a year they just didn't feel secure to me.
Last year I added water cooled marine air conditioning. I installed a new Series 93 OEM flanged valve using the buttress thread thru hull with mushroom head. This was in a new hole I drilled into the hull.
That valve feels much stronger, very secure. So much so I'm replacing all the valves I installed in 2019 with 93 Series OEM flanged valves with buttress thread mushroom head thru hulls. I'll mount them in the molded in recess like @Hayden did and use 3 1/4" round, 1/4" backing plates mounted in thickened epoxy.
I hope that better explains what I did, will do and why. PM your phone number if you want to discuss in further detail.
Forespar sent me 11 documents, including their 30 plus page Marelon Catalog. PM your email and I'll forward them to you.
Apr 5, 2009
3,327
And the other option is to use the CF250 recessed thru-hull but have Forespar mount it with a special order NPTS thread instead of the buttress thread.
Ward H
Nov 7, 2011
3,842
I considered this but the wall thickness of the buttress thread thru hull is thicker than the CF250 and the buttress threads are supposedly stronger, which I believe will produce a stronger overall install.
Still, I agree, if you want to keep flush head thru hulls, it is an option.
