I hope I don't seem fixated on through hulls. One question is bugging me. I see adds for wooden plugs to use in case of a through hull failure. How are you supposed to use them? I don't know what you would do with one. If a through hull fails, how does it fail? Does it leak around the fitting through the hull? Is it the valve that fails? Do you remove the entire through hull or just the valve when it has failed? Obviously, I am referring to when the boat is in the water and I suddenly have a rapidly leaking through hull. I plan to this spring take a good look at the through hulls on my boat to understand them better. But what do you do specifically in an emergency?
Mike,
Wooden plugs are for a catastrophic failure of the seacock or a snapped off thru-hull. Considering I have personally snapped one I have a good understanding of why it is important to have them on board.
Here are a few things I'vefigured out over the years.
#1 I keep them in a sealed ziplock bag as close to the seacock as possible, as opposed to fastening them off to it with string. I use Gorilla tape to secure the bag to the hull.
Tapered plugs are meant to swell when pounded into a seacock or a thru-hull. If they have been sitting in your damp bilge with 95% RH they won't swell and seal as well as they will if kept dry. Thye will still swell but they will seal better and stronger if you pound them in from a dry state rather than very moist state.
#2 Don't forget a mallet to pound them in with. Once pounded in they will swell and become quite dificult to remove.
#3 Test fit them prior to storing them in the location of each seacock. Many times I've found the need to cut them shorter (the wide end) so they could actually fit into the seacock or thru-hull.
#4 If you suffer a hose failure simply close the seacock. Tapered plugs do not generally need to be used for hose failures unless the seacock is inoperable. For hose failures double ended hose barb splices and hose clamps are the best medicine to effect a repair. It's a good idea to know the diameter of every underwater hose and then to have the matching OD to ID hose barb splices on board.
#5 If you have an area with more than one seacock, like under a sink, and you will have a bag of say three tapered plugs for each seacock you should write on each with permanent marker. This ensures that in an emergency you grab the right plug. It is always a good idea to label all your seacocks..
While I love wax Johnny Rings they are not something I would personally use in a thru-hull failure situation. Often a failure will occur when it's rough, as happened to me. The hydraulic pressure created by a boat smashing off a wave in rough seas will be considerably higher than the static pressure created by a boat just sitting there in benign conditions.
Tapered plugs are designed to swell once pounded into the orifice and they create a mechanical seal. Wax makes no mechanical seal and will need tape or another sort of way to prevent it from being pushed back into the boat. Tapered plugs are also faster to use..
Keep in mind that a 1" hole two feet bellow the water line lets in 27.8 Gallons Per Minute. That's 1668 gallons per hour! Even a 2500 GPH "Rule type" bilge will barely 400 to 700 gallons per hour when hose restrictions and head pressure are taken into account..
