Strong spring on throttle
I had a similar situation where water dripped on the throttle lever on the engine and caused quite a bit of rust, gumming up the works. However, even with all the rust removed and everything working normal, the basic problem is that the spring used inside of the governor mechanism of the engine is very strong, and when you adjust the throttle lever on the ped guard for more throttle you have to work against this stron g spring. Try removing the cable on the engine and then move the lever on the engin..you will see it takes quite an effort. For this reason I do not like the idea of friction on the cable with a clamp, as is normally done. I plan to try installing another spring that would aid the the throttle lever action on the ped guard and reduce the amount of effort required to overcome the spring tension inside the governor.Sure would like to hear if anyone has tried this.Ernie
