N
Nichole
Can someone also please tell me if you use any cable lubricants on the throttle. The throttle is very hard to push or pull which does not make for a very smooth ride at times.I've adjusted the cable break to hold the throttle in place and it is at the absolute least tension it can be without having the handle constantly fall out of speed.What else can be done to get a smooth throttle and have it hold any any given rpm?
