Three blade prop vs. two
425
- - Sandusky Harbor Marina, Lake Erie
Using prop wash
Here are a couple of examples: Tie up to a wall port side to. Approach at an angle. When the bow is close, reverse the prop, and prop walk will pull in the stern. Turning right into a slip. Pass the slip, do a u-turn to port in the chanel. Then you are turning to port on entering the slip. Pulse the engine in reverse. Use good hard pulses to get speed up quickly, and allow correction to starboard with the rudder between pulses. This is probably the most important technique I have learned. Balance prop walk with a stern line. When we cast off ot back out of our slip, we keep the stern straight during the first pulse by pulling on a line to starboard. Once we are moving and have steerage way, we cast off that line. As a final note, I don't believe there are complete solutions to prop walk, which is caused by the differential pressure from the top of the prop to the bottom, the clearance at the top, and the angle at which shaft leave the hull, all of which make sideways thrust of the lower blade of the prop more effective than the upper. We do have the modifications from Bay Prop in Alameda, and can recommend this solution. The principle advantage for us has been a half knot increase in our top speed, and a reduction in vibration. We still have the (slightly reduced)prop walk! David Lady Lillie
Bob
Keeping it simple
OK guys! I want to keep this as simple as I can. Yes, I know about prop walk and I do use it to my advantage. But it's of almost no use to me when I'm trying to back my boat into it's slip from a dead stop. That's why I (and some other in my marina) use a "cheater line". However, the ones that don't have a three blade prop and have very little problems backing in. Yes, I know that there is drag from a three-blade prop but is it really that bad? It's a balancing act I'm sure. This winter I'll have the time to ponder this question and may go with a two blade feathering prop. From all I've read so far it's MY best solution. I simply want better control in reverse from a dead stop and less drag while sailing.
May 25, 2004
450
Catalina 400 mkII Harbor
u turn??!!
you must have nice wide fairways, come to chicago and try a u turn, ha ha mike
4
- Hunter -336 Swansea, MA
Campbell Prop
Jim, What Model is your boat? We have a Hunter 336 and are planning to head down the ICW from our home in MA this Fall.. Sounds like it would be perfect? If I purchase the Prop I will have a potential time crunch as the Company is closed until August 10th (vacation).. Were they prompt on your delivery? Wilkie
Mar 22, 2004
26
Hunter 31_83-87 Norfolk, VA
campbell prop
Not exactly prompt, I believe they make them by the order. But they did get it to me well within their predicted time. I believe it took 3 weeks from the time I ordered it till I had it. They are good people give them a call. I have a 1985 H-31. If you tell them what boat and engine that you have as well as the transmission reduction ratio they will tell you what prop you need. My prop size dropped 1" and pitch 3" going to a 3 blade. With this prop my engine max rpm now is about 2800 RPM at about 2400 RPM I cruise at 6.5 knots with a clean bottom.
