I have a 1997 h40.5 with two Marine Air Reverse-cycle A/C units. One is a 16K BTU and the other is a 5K BTU. Last fall the 16K unit failed and presented a high current on start-up in heat mode - about 35A - and tripped the breaker. My notes from last fall don't tell me if it also fails in cool mode, but I will check out everything after I get launched this year.
Does anyone have any T/S suggestions as to where to start to isolate the problem? I don't get any error codes on the temp display.
It is a Marine Air model VRP16K.
