pclarksurf; I'm new to this forum, but thought I might have something to add here...
My manual bilge pump is a stock mounting (1984 swingkeel Catalina 22) in the port side lazarette wall with the handle operated from within the cockpit. It discharges via a 1" thru-hull fitting located in the transom about the level of the motor mount (and very near to the motor mount). When I installed an automatic bilge pump (many years ago when the boat was in a slip full time), I simply installed the electric pump at the intake of the manual pump hose, which is located at the lowest point of the bilge under the stern-port settee seat (in the tight "corner"). With this installation, my electric bilge pump can operate on automatic and pumps right through the manual bilge pump (with very little headloss). If the need for the manual pump ever arises, it works just as normal, whether or not the electric pump is operating. The electric pump becomes the intake point for the manual pump, which offers the advantage of the very low water scavenging abilities of the electric pump (down to about 1/4"of water). This system has worked for me for 19+ years that I have owned my boat. Hope this is helpful.
