What about
You might try jacking up the trailer and setting it on blocks or running the tires up on railroad ties or somthing to get it a little higher off the ground. Somtning else you might think about. Unlike power boats, most sailboat trailers are set up for the weight of the boat to set on the keel, if the weight is on the hull, you might be deforming the hull.Good luck,Herb
