I second earlier re-torquing. On engines in which its easy to do, I almost always re-torque after the first hour or two, then again after 100 miles (10-20 hours), then at 1000 miles or 100 hours.
Re-torquing more than once or twice wont ever hurt anything, just make sure to back off each head nut or bolt 90 degrees or so before bringing it back up to full torque. Another suggestion is making sure the nut or bolt doesnt squeak or chatter as you torque it, it should be be quiet and smooth, allowing the full clamping force to be reached. We often have to oil or grease the threads and washers so that this can occur. Chattering means the threads are seizing and you will indicate full torque while not actually reaching it. This is in fact the reason many manufactures went to lower initial torque, then rotating 90 degrees, which would allow the chatter to have no real effect. Just to be clear though, you dont loosen all the bolts and then retorque them all, you do each one in turn, one at a time, following the prescribed pattern. You can even go around two or three times if you want, and will notice you gain a bit more each time on the bolts, showing that your squeezing the gasket down even further, which is ultimately the whole point. By doing it on a hot engine, the gasket will be more pliable and soggy, further allowing more compression of the gasket to take place.
