It's all HERE.Not aware of any Don, do you have a name or link?
Dennis
http://www.sailrite.com/Headliners-Liner#!Headliners-Liner
Dennis
I pulled out all of the old, nasty "insulated" vinyl sheets in my hunter, some places all full of moisture and black mold behind. This BTW exposed the leaks that I had hidden in the rub rails.You know they made insulated vinyl sheets in rolls just for putting on the inside of hulls or for headliners?
Truth to this for sure.I pulled out all of the old, nasty "insulated" vinyl sheets in my hunter, some places all full of moisture and black mold behind. This BTW exposed the leaks that I had hidden in the rub rails.
Sure, it looks nice and the spongy feel to it gives you the impression that it has "some" R-value to it's insulation properties, but in reality it's practically non-existent. I then thought that maybe I should put some sort of insulation blanket behind it until once again I came to my senses and decided against it.
If there is ANY moisture penetration, how am I suppose to notice and fix it? The vinyl crap that was in before certainly didn't notify the previous owner that there was moisture.
NO THANK YOU.
Instead, I installed dark grey outdoor rated, UV protected carpet from lowes/homedepot and just glued it in. Every now and then I run my hands against it and even with my moisture meter to look for any issues.
At least NOW I'm able to detect "wetness" and address the issue, not just hide behind it and wait for mold to grow and infest the boat.
Use a nice outdoor rated (thin) carpet, and forget about vinyl.
True. I use a dehumidifier in the winter. But it REALLY helps if the boat is water tight, especially in the PNW [grin]. I found about 10 holes in various locations hidden by the black rubber rub-rails which was the source of the most insidious leaks.Truth to this for sure.
But you have to admit, you live in the sailboat mold & mildew capital of the world. Most of my Puget sailing buddies have electric dehumidifiers in their boats running almost all of the time. If you don't stay on top of it there, it takes over.
Remove it if you can. Makes a real nice job.to get the carpet from behind the storage on the sides?
