A shelf foot is an extra panel sewn between the body of the main and the
boom. It is there to add extra "shape" to the main when the outhaul is eased
in light air. Sometimes it is of a slightly lighter weight cloth. Obviously
they aren't used on loose footed mains.
I have been reading the comments on trysails. I have to agree the Vega
already has a pretty small sail area. The big advantage of the trysail is
that is it loose footed. I've had them on bigger boats and usually used a
rope "horse" to control the clew. I used two stern cleats with a line
between the two. I also has a separate track. Trying to get a sail down and
then another sail up, when you realize you realize you need to do this
(obviously it is already pretty nasty) isn't easy to do. I've installed an
extra track next to the main track and it works OK. But again, I really
don't think it is necessary on a Vega.
AlbinVega@yahoogroups.com [mailto:
AlbinVega@yahoogroups.com] On Behalf
Of vegatern
Sent: Sunday, March 16, 2008 8:58 PM
To:
Subject: [AlbinVega] Re: Third Reef or Trysail?
Dieter,
Your trip sounds great. I hope you can find the time to share more of
it. You have much more experience than I, and I am reticent to put a
word in, however from what I've read, and for what it's worth, . . .
When the Coghlans left on their circumnavigation they had three reefs
and a storm jib. They later added a fourth reef and a smaller
"cyclone" jib. An account of their trip is in the voyages section at
the American Vega Assn website. The Tern has a third reef, though I
have yet to need it. Light air performance is put off a bit by, not
so much the reef points, but by the weight of the reefing lines
through the clew rings in the leech. I need just a little wind to
stretch out the sail. Some of this may be due to the fact that the PO
had the main cut with a shelf along the foot, a bit of a bag so to
speak. This issue has been rectified with the recent purchase of a
light weight drifter which works like a dream. ( I haven't thanked you
yet Ed, but you were right. Just the slightest ripple and we're
sailing again. Thanks)
I've been told that the Vega is too small for a trysail but
Tania Aebi used one on her Contessa 26 and I would think being able to
take stress off the main and boom may be helpful. I think I would
take the time to add a separate track, on the theory that is would be
easier to install at the dock than at sea the night I decided to use
it ;-) The other issue is where to run the two sheets. I suspect to
blocks in padeyes on deck somewhere and then back to what? The sheet
winch would be occupied by the jib sheet. Securing and adjusting a
flailing trysail sheet to a horned cleat sounds like trouble, though
perhaps, as Walt suggests, the jib would not be used.
Had a tremendous sail today, on someone else's boat. An honest
35 kts (well, gusting) and 6 ft swell. Sunday races. What fun!
Could someone tell me what IS the purpose of a "shelf" in the
mainsail?
Craig Tern #1519
