The shower in my Catalina 30 drains directly into the bilge and I am probably going to add a sump pump into the bilge area for the shower. I was looking around and saw that I can probably buy one for $100 but I am not sure if it will fit into my bilge. I am thinking about building a sump pump setup but I am not sure what to build it out of. I thought about getting 1/4 inch plywood and fiberglassing over everything to create a custom sump area. I could attach a bilge pump with a float switch in that area and maybe add a screen area to filter the water before it gets to the bilge pump. This way I know that it will fit in my boat. I could put a cheap plastic throughhull attachment in the box that attaches to the hose that runs from the shower drain.Has anyone done a project like this?Where did you lead your drain hose to?Can I splice into the bilge pump drain hose without backfeeding the sump water into the bilge pump?How should I attach the sump pump to the bilge area?Any other suggestions?
