Perhaps I'm a little clumsy . But when rigging the main don't you think we could rig something better than the little pin? I ask this as I order another one from CD having dropped mine overboard today.
We have a 34 dated 1986 she has always tipped to Port about 2-3 % checked water fuel equipment all seems equal. What could be causing this and of course some cures. Not to sure had to start a thread or to research this subject already. ThanksUPSGUY said:Perhaps I'm a little clumsy . But when rigging the main don't you think we could rig something better than the little pin? I ask this as I order another one from CD having dropped mine overboard today.
if this were a C22 I'd say.... perhaps this person should just sit closer to the centerline............Or, if you ran the boat aground, you could have upset the keel. Have you seen the keel lately?
http://www.mcmaster.com/#linch-pins/=j8e6hv like this?Yep. I sort of hated to say that, but when I launched and setup the boat every time, that is exactly what I used. I still keep the lynch pins on the boat in case of an emergency. They are very quick, and strong. I've never seen a stainless one, If so, I would own it.
I know that the galvanized pins rust, but at a couple dollars apiece, I can replace them as often as I want. I loath those little ringy dingy things with a passion. The lynch pin is a whiz-bang when it comes time to set up..
http://www.c34.org/faq-pages/faq-port-list.htmlWe have a 34 dated 1986 she has always tipped to Port about 2-3 % checked water fuel equipment all seems equal. What could be causing this and of course some cures. Not to sure had to start a thread or to research this subject already. Thanks
The quick pins have a shear strength of about 9200 lbs, a low grade clevis pin has about 2000 lbs less and a high grade clevis pin is about 10000 lbs.Something to think about, those "quick-pin's", although 1/4" OD, they are hollow, so the effective strength of them compaired to a solid 1/4" pin would probably be less. Convienent, yes, but I wouldn't use one the forestay, just my opinion....
Don
Yup that's the one. I ran a bolt into it to sail that day but it didn't seem to thread right. Whatever I use I'm going to tether to the boom in some way.GorillaToast said:I'm just a little confused here...
It seems in the OP, that UPSGuy is talking about the threaded pin used to secure the mainsail's tack to the boom. Then suddenly a few posts in someone is talking about the balance of the boat causing it to list a few degrees...???
What is this thread really about?
Hi Don, I'm not sure about the effective strength of one of those quick release pins but CD is selling them for the purpose of fastening the forestay on the C22 and the C25. One culd ask them if they are concerned. My concern would be of fouling the ball/spring with dirt and having that pin come off without breaking.Something to think about, those "quick-pin's", although 1/4" OD, they are hollow, so the effective strength of them compaired to a solid 1/4" pin would probably be less. Convienent, yes, but I wouldn't use one the forestay, just my opinion....
Don
