Paul
The gelcoat below the water is quite thin. The previous Beneteau owner had warranty work done to remove blisters. Beneteau skimmed off a thin layer of the gelcoat to fix the problem and now I have a hull with less gelcoat. There were 8 dime size blisters that I fixed with 3M polyvinyl patch and covered with VC17 antifoul. What should I do next year? Repatch the the new blisters or do a complete epoxycoat? This is a freshwater vessel that spends the winters on a cradle.Comments
