Stiff Decks
The classic way to stiffen a deck section is to laminate a semicircular fiberglass beam underneath it.Typically, a cardboard tube is cut in half lengthwise and taped to the underside of the deck to act as a form. Then, overlapping strips of fiberglass cloth or roving are epoxied over the tube, usually 3-4 layers. If the area is large, you would lay up more than one beam.The problem, particularly with a smaller boat, is getting access to the area that needs reinforcement.This doesn't fix a deck that's spongy because the core is rotten. This stiffens a deck that is too springy because it's too thin.This is such a typical repair that you can pick up almost any book on fiberglass repair and find an example: My favorites are the Hinckley Guide to Yacht Maintenance, Don Casey's excellent book on fiberglass and hull repair, and the West System epoxy repair guide.
