Thetford recirculating toilet
N
NJArnfield
We have a recirculating toilet by Thetford (if I read the labels correctly) on an older boat which we just recently purchased. We cannot seem to get it to work properly and can find no instruction booklet. Can anyone give us any suggestions?
Dec 2, 1997
8,975
- - LIttle Rock
The only recirculating toilet Thetford still makes is the "ElectraMagic"
Which, depending upon the age of your boat, may not be the one you have.
http://www.thetford.com/HOME/Products/PermanentToilets/ElectraMagicModel80RV/tabid/116/Default.aspx You can download the manual for it from there. If that's not your toilet, give Thetford a call.
However...recirculating toilets are not a good choice for boats. They hold only about half the flushes a portapotty does and really start to stink if not emptied just about daily. So if it were my boat, I'd toss the d'd thing overboard and replace it with a 5-6 gallon "MSD"portapotty (MSD means it's designed to be permanently installed and is fitted for pumpout). Check out the Thetford 735 MSD here: http://www.thetford.com/HOME/PRODUCTS/PortableToilets/PortaPotti735Marine/tabid/158/Default.aspx
N
NJArnfield
Thanks for the reinforcing view!!!
I had thought perhaps booting it might be the best choice. I will follow up on the various suggestions.
