As some of you know, I picked up a Rhodes 22 for only $250... YES! It need work
Today I started the final repairs on a hole I discovered once I removed the thick layers of bottom paint.
I have been following the advice from Don Casey's "Complete Illustrated Sailboat Maintenance Manual" If you DIY I recommend you get a copy of this book.
Anyway I attached some pics.
Today, I installed the backing plate. I had to use a rather sequitous procedure because I don't have access to the inside of the hull at the location of the hole.
I still have to complete the exterior layup and I'll post pics of that later.
r
r
