Talked to them at Seattle Boat Show
The unit looks well built - stainless steel, etc., and the idea of using it to heat the boat sounds interesting. However, if it raises the relative humidity inside the boat - which it will - this can cause mold and mildew. The choice could hinge on how it would be used - live-aboard vs. short cruise mode.In our area the boat interior often gets up to 85%RH and it needs to be as a minimum below 50%RH and preferably below 40%RH to combat mold and mildew. My guess is that in the area around the Strait of Georgia would experience similar %RH to us.The best heat for this coast is forced air because it's much drier and helps to force out the humid air.For live-aboard use a hot water heating system would aggrevate the %RH but for 'short cruise mode', where one is out for a weekend or a couple weeks at a time, then the impact should be minimial if on return the boat is dehumidified. For a short duration I wouldn't think mold and mildew whould have a chance to get started, take root (!), and grow.If one goes on a longer cruise - Shearwater, Price Rupert, SE Alaska, then forced air would be just about the only way to go. These areas are really humid.These would be my thoughts and I discussed these with the salesman at the booth, and I think he was some kind of owner or so of/with the company, but he didn't feel that was a problem so there are definitely different views about this.By the way, another thing to think about is the exhaust vent for the heater unit. Most water heaters are placed amidships so the exhaust would be through the hull or maybe the coachroof. These are not the best places for a very hot exhaust. Hull, if thats allowed, the docklines or fenders should be watched and coachroof heat could cause other problems. On startup, for example, soot could be created causing a mess on the white gel coat.Not all is gold that glitters. Hope this helps.
