Teak Maintenance
Rick,You sure know how to ask an open ended question that has absolutly no single right answer. The effort that you put into your teak is strictly up to the end product appearance that you wish. Whichever route that you take, you start the same. Sand the teak smooth, use a good teak cleaner and then a teak brightner. From here, you take one of two roads, Teak Oil or "The Other." With the varnish route, (Cetrol, Cetrol Light, or West Marine house brand) it will need about 3 coats on the first application, after that, a light sanding and about 1 coat per year. The original Cetrol has a orange tint to it, where the Cetrol Light has just a shine. This route has an execllent appearance to it, but does require a little more effort on a yearly basis.If you choose the Teak Oil method, you will also need about 3 coats initially, with a touch up of oil about every 6 months. The teak will turn to a gray color which is normal. Many people prefer the natural look of teak, the way teak was done "back then." It all comes down to how you would like it to look, and the amount of time you are willing to invest.Ben AllenMontgomery, AL"Wahoo"O 26
