The Perfect Storm? (Really: H45DS steering issue)
H45DS
Aug 12, 2010
55
Hunter 45DS Portland, OR
Questions on a H45DS steering issue
This is my first post to the board, and it is a long one so please go easy on me! :)
We own a 2008 Hunter 45DS that we took delivery of in September 2008, and we love it. It is roomy enough to liveaboard should we choose to do so, yet it is also very comfortable on the Columbia River where we do most of our sailing. The boat has a very easy helm – I’ve never “run out of rudder”, and even in all but the heaviest winds I still have fingertip control of the helm.
While sailing up around Vancouver Island a couple of months ago, we developed a very "heavy helm"… meaning that it took a lot of effort to turn the rudder. When the rudder moved, it did with a "shuddering" feel, and had an audible squeaking sound. I suspected that we may have snagged a crabpot, and gotten line wrapped around the rudder post, but there was no indication of this. I was very concerned about making it from Port Angeles, WA back down to Portland, OR given this issue, but we decided (rightly or wrongly) to make a run for it given the offshore conditions were favorable and the autopilot was able to control the boat with no apparent issues. We made it safely back to Portland, and immediately took the boat over to our favorite boatyard for diagnostics. When they hauled-out the boat, we made sure to check to see if we had hit something with the rudder, and we had not - it was completely unmarked and the rudder post was straight as an arrow. The boatyard found two separate (related?) issues: the autopilot clutch was not fully releasing, which was putting a lot of drag on the helm linkage; and the rudder post bearings were flattened in several areas on the port and starboard sides. It turns out that both systems are produced/sold by Edson and used on the H45DS. The boatyard contacted Edson, who informed them that the autopilot clutch mechanism was not a serviceable item, and needed to be replaced (did I mention this is a $3,000 item?? :doh:). Fortunately, the boatyard did a little investigation, and found that three screws had backed-out in the mechanism, which was preventing the clutch from completely releasing. A little Loctite on the screw threads rectified this problem (whew!). Edson also informed the boatyard that the rudder post bearings were sold as a tube assembly, which contained the bearings inside a tube (I presume this is done to facilitate new boat construction), and that the earliest they could commit to ship this item was mid-September if no other boat manufacturer had a need for it. The boatyard was able to purchase one directly from Hunter, at a remarkably high markup ($2,300 from Hunter versus $1,000 from Edson). With all this information, I would appreciate your counsel on a few questions:
1. Has anyone else had a similar experience with their Hunter sailboat, and if so can you provide specifics on what you experienced?
2. Hunter is telling me the boat is out of warranty, and technically they are correct since we are past the one year mark of ownership. But this type of failure feels REALLY premature to me, with less than two years of light river sailing. Should I expect Hunter to step up and help out with the repair costs, or is that unreasonable?
3. Should I expect Edson to step up and help out with the repair costs, or is that unreasonable?
I understand that “stuff happens”, and if I’m out of line expecting a little help from Hunter and/or Edson, then I can accept that. But this strikes me as a very unusual failure mechanism, and something that may warrant a little assistance.
Thanks in advance for your input.
Regards,
Gene
s/v Symmtery, H45DS
Portland, OR
485
Hunter 44 Mystic, Ct
Perfect Storm
Gene
In response to your three questions:
1) While I have not had an opportunity to check the rudder bearings on our 2005 Hunter 44AC I do recall that sometime last year we were out sailing with the auto pilot on and I forgot to disengage the unit before attempting to self steer the boat. Obviously the helm was very stiff though I could override the autopilot. I did get that shuddering that you mention. After about 2 or 3 minutes when I realized my mistake and disengaged the auto pilot everything was fine with no apparent damage.
2) While we absolutely love our boat, this is our second new Hunter, warranty support from the Hunter factory has been less than satisfactory. Our local Hunter dealer whom has since gone out of business had often served as a go between on factory related warranty issues and had some success however we are now on our own and can't get anywhere with the factory. In fact our boat came with a 5 year bow to stern extended warranty however the third party insurance company is in bankruptcy and Hunter has not offered to step in and help. (I understand that they are not legally obligated to do so, but having spent in the neighborhood of $400K for two boats over 6 years, i guess I would have expected a little more). I recently had to replace my balmar alternator and voltage regulator, (only 150 hours on the engine) and could not get any financial support from Hunter.
(3) You might have some luck with Edson. Certainly worth a try. When our black box contactor failed last year on our Lewmar power winch, I called Lewmar and they supplied a new contactor at no charge. Edson might be willing to do the same if you explain the situation to them yourself.
Marc
Jan 28, 2008
9
Hunter 41DS Bradenton
Gene
Marc
Marc,
Do you happen to know the name of the extended warranty company that is bankrupt? Curious if it is the same company that holds our warranty on our 2008 41DS.
Thanks......
H45DS
Aug 12, 2010
55
Gene
Marc
Thanks Marc! I appreciate the advice, and will call Edson/Lewmar to explore how they may be able to help in a meaningful (read: financial) way.
Some new-news since the original post... the plot has thickened a bit. Just yesterday the boatyard discovered that the bearing assembly had at some point along the way been damaged and a repaired was attempted. Apparently a part of the problem is that the repair broke - not sure why/how. Since I'm the original owner of the boat, and the rudder has never been removed by the boatyard we use, the implication is that this was a manufacturing issue either at Hunter or at Edson - not sure which. I suppose the good news is that this may help me gain some assistance from Hunter or Edson. I've attached a couple of photos to show what the entire bearing assembly looks like (it's BIG), and what the break in the top part of the original bearing looks like. The photos came from a cellphone, and the quality isn't the best - hopefully they are good enough to convey what the boatyard is seeing.
I also just learned about the issue with the extended warranty vendor. Disappointing in that this represented $5K that I paid toward my boat that was a complete waste of money. I could have "invested" that money in some fun toy(s) like HD digital radar, AIS, etc. ;)
The boatyard has indicated that we may be back in the water late this week. I hope so - would be nice to spend the weekend on a working, steerable boat.
Take care,
Gene
500
Hunter 36 Chicago
Would the 5 year warranty for hull blisters be covered by the same insurance company? I'm supposed to have some blister repairs done this winter under Hunter's 5 year warranty. If they don't cover it I'm screwed as I don't have time to do the repairs myself and I don't want to pay out of my own pocket.
Jan 28, 2008
9
Ken,
You should be just fine. The hull warranty is carried by Hunter itself and not part of the extended warranty.
Regards,
Bill
