- Oct 22, 2014
- 23,792
At the basic level I agree.tension being all about the mast. Don't look at a guage or a tape measure, look at the mast.
It is about the mast, but not alone. It is also about the rig. Equally, what it is doing to the boat and the hull. I called it the art of the rigger. It is not tuning the mast or the stays/shrouds. It is about tuning the boat.
Most of the time watching the rigger the initial process involves positioning and aligning the mast. The gauge is used to look at the value of ten being applied to the rig in order to set the mast. Getting to 15% was a general target number. Not an in stone requirement. Perhaps 12% achieves the needed tension to set the mast rake and prebend (when called for by the mast maker and boat designer). When you get to that point you need to be certain that your tension is not deforming the hull.
