Posted underway from the scene of the oil loss incident:
Cruising at 2300 RPM for the past 3 1/2 hours with not sign of oil leakage or high crankcase pressure. I ran at 2400 (80%) continuous power for a while to be sure things were good and hot and the engine working.
I‘ve been checking frequently. I pulled the oil breather line off from the downstream side of the liquid trap and can just barely feel the slightest pulsing outflow. No additional oil or even condensation in the trap. I took off the oil fill cap and the outflow is what I would describe a baby’s breath, maybe a very sick and weak baby. Anyway, it is nothing like was coming out yesterday.
I never added oil after the brief burp I experienced at the dock. Dipstick read about 3 – 3 1/2 quarts this morning. That’s about 1/8” below where I usually fill it. The Portsmouth mechanic who put the gasket in filled it with 4 quarts putting it about 1/4” above that. I put the same amount in when I drained and refilled yesterday.
I think yesterday’s blow out was a burp. Pressure built up due to the higher oil level than I have run at for the past 5 years. The dipstick popped up and spewed oil until the pressure equalized. It then dropped back in. The high outflow from the filler cap I saw after that yesterday was probably the result of oil blow around where it shouldn’t be. Overnight everything drained back and the engine is running normally.
I think the last post in my previous thread have nailed it. I have been running right on the hairy edge of the maximum oil I can get away with while pitching heavily. That little bit of extra created all this educational entertainment.
One last look: Everything as previously described except that I can’t feel anything coming out of the oil fill cap now.
