Funny thing about water...it only wants to run downhill. You aimed your discharge fitting to run straight UP, so any water in the bowl would have to run UP hill to drain (it's not a siphon) out of the bowl. However, as your new joker valve becomes worn, any water left in the discharge fitting or in line above it will start to seep back downhill into the bowl...more quickly as the slit in the valve gradually gets wider due to wear.
