In many of the posts I have read, the boat owner is debating the need for upgrades on his boat. Adjustable genoa sheet cars are one of the options under discussion. Some skippers think that because they only own one head sail, there is no need for adjustment. Also pin locked cars are such an inconvenience to use that many skippers refuse to make any changes(and I don't blame them). AGSC's are a necessity if you expect to get your sail trim right. Various points of sail require different sheet lead angles. Likewise, varying wind strengths require different lead angles.Line control sheet cars make adjustments very easy and allow the skipper to get the sail trim correct. In heavy air, moving the cars back depowers the top of the sail decreasing heeling moment and making the helm easier. When reaching or running wing on wing, the cars get moved forward to allow maximum leech opening, which allows the sail to 'breathe' for best performance.Many manufacturers do not install adjustable genoa cars because it adds initial cost to the boat. This is actually false savings because adding the tracks afterward costs more than doing it at production. Never the less, it should be the very first upgrade that any skipper puts on his boat. Your boat will thank for it by sailing better!
