Hi Paul j, photos of the Hoyt jib boom installation,the stainless steel support is 100mmx100mmx6mm angle with a side gusset welded to it that allows you to bolt directly to the anchor winch support.This take any downward force fron th boom. The cleat under has been moved forward near the other inspection port. As you can see there are no bolts showing in the main cabin,they all just fit between the timber and the f/glass anchor locker wall.
There is no flex in the deck.
cheers Curlew
cheers Curlew
