Don Guillette
Mates: When the good folks at Sailboatowners.com gave me the opportunity a while back to host this Forum I started out with an article similiar to this one. A lot of water has passed under our keels since the first article so I thought it would be a good time to re visit the subject. This article will appear in the next Mainsheet Magazine, which is the Catalina owners magazine. THE FOUR ELEMENTS OF SAIL TRIM How many times have you wondered what sail trim is needed for a particular wind condition and point of sail? Do any or all of the sail trim controls on your sail boat confuse you? Your not alone as most sailors are confused and intimidated by all the sail trim controls for the mainsail and jib and consequently, either do not use any of them or use only a few. Additionally, many sailors have little or no idea why they are making a particular sail trim adjustment. This article, and other that will follow, will take the mystery out of mainsail and jib trim. Sail trim is an acquired art and simple to learn and understand but it has to be presented in an easy to understand fashion. Hopefully, I can accomplish that goal. Sail trim is not nuclear research. In other words, it is not a never ending process. It’s like riding a bicycle – once you learn to ride your there. You’ll probably be surprised to know that all the sail trim controls for the mainsail and jib are only adjusting four things and they are draft depth (belly), draft position, twist and angle of attack. Once you have an understanding of those four elements – your almost there. Without an understanding of those element your nowhere! That’s how important they are. Let’s start with the first two elements. Why do we have to understand DRAFT DEPTH (belly) and DRAFT POSITION in the first palce? We have to understand them because they control three things – POWER, ACCELERATION and DRAG. Drag is actually friction, which detract from power and comes from the rudder and keel. A sail is like an airplane wing and if a plane flew sideways it would be called a sailboat! The planes flaps, in the up or down position, produce a deep shape (like a belly) and are used for takeoff and landings. No flaps or a flat wing create less drag and are used for high speed and cruising. Drag on a sail boat has to be minimized or it will simply detract from your speed. Where does the POWER to power a sailboat come from? It comes from three things. The first is the SHAPE OF THE SAIL, which is either deep or flat. The second is the TWIST of the sail. Incidentally, your twist adjustment is one of the most important sail trim adjustments you can make. The third element of power is ANGLE OF ATTACK. The first element of sail trim we’ll discuss is DRAFT DEPTH. What is draft depth (belly)? It is “the % of sail width at a given point”. To understand that definition we have to briefly touch on DRAFT POSITION, which is “the point along the CHORD where the maximum depth falls”. This is probably getting a bit confusing, but hang in there with me and it will shortly become clear. I’m not going to define chord but instead give you a simple procedure to get you into the chord ballpark. I want you to measure the foot of your sail and then mark the halfway point on your boom. In other words, if the foot of your sail is 10’ long, mark the 5’ position with a piece of tape. From a draft position stand point, that 5’ mark is called 50%. The 4’ mark would be called 40% and so on. From a draft depth stand point we also want to continue to use the 10’ length of foot of the sail. So, if the sail had a 1’ belly, the draft depth would be called 10%. If it had a 2’ belly it would be called 20% and so on. There is one more piece we have to look at to put this all together. You have to look at the deepest part of the belly of the sail and imagine a vertical line going from top to bottom and intersecting the boom at some point. Where that imaginary line intersects the boom is called the DRAFT POSITION. If it intersects at the 4’5” mark, it is called 45%. If it intersect at 5’5”, it is called 55%. Let’s put all this together. Assume the skipper decided that the point of sail and wind condition he was sailing in needed a 20% draft depth and a 50% draft position in order to obtain 100% efficiency from his mainsail you would understand that he wants a 2’ belly in the sail and he wants the imaginary line that runs through the deepest part of the belly of the sail to fall at the 5’ mark. The mainsail controls you would use to adjust DRAFT DEPTH are the outhaul and mast bend. Increasing pressure on either of those controls reduces the belly and decreasing pressure increases the belly. The mainsail controls for DRAFT POSITION are the boom vang, Cunningham (or halyard), mainsheet, mast bend and outhaul. Increasing pressure on any of those controls moves the draft position forward and decreasing pressure moves it aft. The next time your on the water try adjusting those controls and watch the draft depth and draft position move. It’s a trip! My next Mainsheet article will deal with TWIST and ANGLE OF ATTACK. Future articles will discuss all the sail trim controls for the mainsail and jib. I’ll describe each one and tell you how each works. You’ll find the future article on telltails very interesting. If you have any questions about any of the above material, please contact me and I’ll do my best to answer your question. In fact, if you have any questions about any elements of sail trim just drop me a note and I’ll get back to you promptly.Don Guillette is the author of The Sail Trim Users Guide and the Sail Trim Chart. His products are available through the sailboatowners.com ships store.
