Don Guillette
TWIST Apparently every one understands draft depth and draft position. Actually, I think most mates found the concepts pretty easy to understand. So now we are half way home in our understanding of the 4 elements of sail trim. Once you understand these concepts, sail trim becomes a piece of cake. Twist confuses a lot of mates but it is also very easy to understand. On any given day in Long Beach harbor, or any area, 75% of the people sail with a twisted main and jib all the time. The actual definition is “The change in the angle of the chord line of the sail to the centerline of the boat at various heights up and down the sail”. No wonder no one understands what TWIST really is. Simply stated, twist is leeward sag of the leech of the sail. To view it, stand in your cockpit and look up the leech of the sail from bottom to top. Assume your sailing close hauled. The top half of a twisted sail will look like it is on a beam reach. The bottom half will look like it is close-hauled. You will never see a twisted mainsail on an America Cup boat or any race boat because Twist is a power robber. Why do we care about twist anyway? The reason is that there more wind at the top of the sail than at the bottom. Why is that? It is because of friction. Friction occurs when the wind passes over the surface of the water. The wind blows 60% harder at the top of a 50’ mast. Sail makers build twist into their sail because of this friction. The LESS a sail twists - the straighter its back - the more power the mainsail and jib develop. The MORE a sail twists – the more the top sags off to leeward – the less power they develop. Fine tuning twist is the most important adjustment you can make. The controls used to adjust twist in the mainsail are the mainsheet and boom vang. Increasing tension on these controls removes twist and decreasing tension increases twist. The control used to adjust twist in the jib is the fair leads. Moving the fairlead forward decreases twist and powers up the sail. Moving the fairlead aft increases twist and de-powers the sail. Obviously, forum space does not permit a detailed discussion of many of the elements of twist but I do discuss these elements in detail in my book “The sail trim Users Guide”. Next time your out on the water, move your fairleads and mess with the mainsheet and boom vang. Watch the top of the sail sag off and then proceed to eliminate the sag. Watch the power of your boat decrease as you increase twist. Any questions?
