That sinking feeling during our maiden voyage
Feb 3, 2014
9
Beneteau 32s5 Cork, Ireland
Over the weekend we took our newly acquired Beneteau First 32s5 out for a sail. During our maiden voyage I went below to find traces water over the floor boards. The bilge was dry when we departed and the worst case scenario went through my head as I quickly lifted all the floor boards in the main cabin to find the source of the incoming water. The bilge was pumped dry and I remained below looking for water. I found when we were hard pressed on port tack water was coming in thru the manual bilge pump hose. Has anyone seen this before? What needs to be done to prevent this from happening in the future? (apart from keeping the boat more upright when sailing).
Gunni
Mar 16, 2010
5,937
It should have an anti-siphon loop in it. From the discharge thru-hull, up to the gunwale, then back down to the bilge.
Beneteau 343 Saint Helens, Oregon OR
I have to keep my sink drain valves closed to prevent water backing into the sink on one tack and spilling out on the opposing tack if I tack fast enough. I usually sail the boat much flatter but occasionally get overpowered and get the rail damp.
Feb 3, 2014
9
Cool, I will check the check valve to see if it is jammed. Thanks guys!:)
