HOW 'bout submitting ideas?
Since few, if any, of us are honest-to-goodness boat designers, why don't we combine our input for what we'd want in an "old style" boat? Maybe that would help the inspiration along a little bit. Of course, Mr. Bob Knott just put a similar request out and it went, ... well, we got a little off the subject.So, here's another approach:For those that would like a Cherubini style or at least a boat with older style lines (no rules apply) please input the following:1. Where are you willing to give up space? Smaller cockpit lockers to make more space below? Smaller nav table to get bigger salon table or vice-versa? Smaller v-berth to get larger head and/or separate shower compartment? Smaller "area in general" to get more cabinets/drawers/lockers? Smaller nav table to get larger nav instrument panel? Shorter overhead clearance to get extra provisions storage low in the bilge? Are you willing to give up some of that engine access to get a few more inches in the head? 2. If you want lower freeboard, where are you willing to make up for it? Would you prefer more boat in the water and then over come it with a larger sail plan with more controls and triple reef points standard? Cutter, sloop, ketch rig? HOW 'bout a schooner? 3. What are your performance requirements? What level of speed are you looking for? Need to win a few club races or are you willing to spend an extra day at sea getting to the next island? HOW stable should the vessel be in a large seaway? Would you prefer a heavier boat if you had more sail? HOW much horsepower would you like, and if a lot, where are you willing to give up space to fit the engine in?4. What's your current favorite floorplan built by Hunter? (Does not have to be the vessel you own, or even one you would consider buying for whatever reason; just look through The Boats and pick one??)5. HOW many of us actually use the stern steps? If used a lot, would it be OK for them to be "hidden" by being a foldout fiberglass ladder instead of the entire transom?6. What suggestions would you have for the "arch" theory? Not have it at all or something "very different" like a double arch that actually looks like a permanent bimini but has one rail for traveller and another for mounting radar, solar panels, etc?7. What equipment should be designed into the boat even if not included at purchase (other than the usual such as macerator, manual bilge pump, etc.)? A/C and heat, refridgeration, SSB antenna setup, ground plates, separate sump pumps, autopilot, radar, GPS cabling, stereo prewired, etc.?8: Aesthetics: HOW many portlights and what shape should they be? What type of toerail? What shape/size pulpits, where and HOW much teak on exterior, optional hull colors, etc?9. Operation: HOW many people do you want to be able to sit in the cockpit at the same time? What number of folks would you want to be able to handle the vessel, do you need to be able to single-hand it? Will you use a spinnaker?10: And last: If you got everything you wanted with only minor compromises in space, size, handling, performance, aesthetics, operation, equipment, and price, HOW long should the boat be to get everything "sized" right? Would you then buy the boat you just designed if it was comparable in price to a current Hunter of similar dimensions?Hmmmm....this boat design stuff is tricky, no? Well, hope we have fun with this!!!! Leaving for FL in an hour, but look forward to responses when I return next week. I should not even mention this so the the folks up north won't be depressed, but I'm delivering a 44' from Ft. Myers to Key West; forecast is for clear skies, lows in the mid-60s, highs in the upper 70s, and 15-18K winds off the beam for the trip. Should be fun. Have a Great Week!!Jay
