Use Ohm meter and 50 Ohm Termination
Remove the antenna from the transmission line by unscrewing the RF connector. Place a 50 termination (purchased from Radio Shack)on the transmission line where the antenna is connected. (Make sure the transmission line connector and 50 Ohm connector belong to the same connector series BNC,PL 259)Measure the DC resistance from the coax center conductor to the oustside shield at the input to coaxial line. It should be close to 50 ohms say 55 Ohms. If ist is not, you may have an open or shorted coaxial line. The open or short would reflect all the transmitters power back into the radio and damage the radio.
