You can't test the RED BUTTON! *yks
You can test the Digital Selective Calling (DSC) feature by punching in a MMSI number for another DSC VHF radio equipped vessel and hailing the other vessel through the DSC. If the digital selective calling feature of your DSC VHF radio is working, the emergency broadcast feature notifying all DSC VHF radio equipped vessel within VHF radio transmission range of your vessel should be working.For recreational boaters the DSC VHF radio is a SOLAS Class D where Test Calls to Coast Stations is not required on the VHF. SOLAS regulated ships requires Test Calls to Coast Stations on the MF/HF (Medium and High frequencies) only. There is no way to test the emergency distress button on the DSC VHF radio. If you hit the emergency distress button on the DSC VHF radio, it will alert every DSC VHF radio equipped vessel within VHF radio range of your vessel. There is no reset button; you have to turn off your DSC VHF radio to kill the broadcast. If you accidentally send out an emergency DSC VHF broadcast, you must immediately call an "All Stations" alert notifying any DSC VHF radio equipped vessel that might have received your distress signal that you are canceling the DSC distress alert.Fair Winds,ClydeCanceling False Alertshttp://www.navcen.uscg.gov/marcomms/gmdss/false.htm
