Test for bad Electronics Module vs Compressor
H
Horace Duncan
My Model DCM-12 Serial # 19216 compressor and fan have stopped cycling on. I have replaced the thermostat to eliminate that. I have verified voltage at between 11.84 and 12.14, most consistently at the higher reading. I could buy a new Electronics Module at $250 but if the module doesn't solve the problem, I will have spent money that should have gone toward the compressor. Question, is there any additional test an owner can do to determine definitively whether the fault is the module or the compressor?
Bill Thomas
module/compressor testing
There is an ohm reading test you can perform to determine which component is at fault. If you would call the factory at 860-664-4911, we will walk you through it.
