Maine,
Can you recommend a marine grade terminal block for 18-22awg wire? I cut my radar cable when I installed it because the connector was too large to bring up the pedestal guard. I soldered them and used heat shrink tubing but want to clean up that install. Is it ok that it is not shielded at the terminal block? I am also using a terminal block to gang the SeaTalk connections on my C70 classic and my RS125 GPS.
Thanks
Thanks
