Hood SeaFlex - Forestay Adjustment
To access (and adjust)the forestay turnbuckle residing within my Hood SeaFlex furler, according to the installation manual with the forestay remaining pinned to the stem head it is necessary to disassemble the furler drive housing. That means: disconnect the jib tack at the shackle; remove the furling line; take apart the top snd bottom drum covers (they're split in halves and form the spool for the furling line); then un-bolt the 10 bolts that hold the two halves of the furler drive housing, upon which the flexible foil will come sliding down the forestay, stopping at the turnbuckle body. It would be best to do all of this while the boat is on the hard, as there seems to be many opportunities to loose parts overboard.
