Hi Phil, In regards to tenders. I recomend inflatables with inflatable
floors. We have a Bombard 9.5 ft with an inflatable floor and it worked well
in most respects. Light weight and could be completly inflated or deflated
on the foredeck. With a piece of PVC pipe as an extension for the Nissan
3.5hp it would plane with me aboard if I kept my weight forward. We towed it
a lot and had few problems. We did have it flip once while being towed and
twice in high winds while tied to the stern at anchor. The Nissan was pretty
easy to get going again after being underwater. We could fit it on the
foredeck if need be but there wasn't much room for sail work or anchoring
with it there. Our rule of thumb was tow it for a few miles, foredeck for
more than a few miles and if it was going to be an overnighter or off shore,
deflated and lashed to the cabin top. We also started had a Sportyak. Double
walled, hard plastic, looked kind of like a cross between an El Toro and a
life raft. It was okay but we were over "tendered" and wound up selling it.
Now that I've said how well the Bombard/Nissan worked I'll tell you why I
wouldn't recomend them. We did need parts for the Nissan and they were
impossible to find in Mexico. If they are available where you are go for it.
Carry an extra prop or two as well as a few extra key lanyards. Use the
lanyards, The 3.5 has an integral tank and after rowing home a couple of
times I started carrying a disposable litre drink bottle of gas as a backup.
That stayed in the cockpit at night and was also a defensive measure.
Firearms were not advised in Mexico. Get caught with one and instant jail.
Being attacked by criminals in a small boat is a rarity. Had it happened
they would have found the gas in there boat and on them followed by a 25mm
flare. Probably not legal to do but definitley legal to carry. The Bombard
is a PVC boat and didn't hold up well in the sun. We also had problems with
the floor seam seperating from the tubes. Next time I'd go with an all
hypalon boat and the only one I know of being currently made is by Achilles.
We did have a problem with someone throwing a cigarette overboard and
landing on our floor. It eas an easy fix. We also had friends with the
smallest model of the Achilles and in my opinion it was a bit two small. A
few last thoughts. Keep the pump and the oars stowed with the dinghy at all
times. A few thaoughts towards a minimal survival kit that would also live
in the dinghy should be some hooks, line, bait, flashlight, mirror,
skyblazer type flares, space blanket, water, candy or granola bars, etc.
Alot of the smaller outboards are 2 cycle and they are becoming
enviromentaly incorrect in a lot of places. A 5 or 6 hp 4 stroke weighs more
but gets better fuel economy and could get you back to your boat faster in a
time of need. Devise a lifting harness to hoist the boat out of the water at
night, We used the main halyard. All for now, dinner is ready. Walt Lyric #
120
