Temporary fibreglass repair
2,955
Hunter 38 Georgian Bay, Ontario, Canada
Noticed a crack on the deck by the anchor locker. I assume I dropped some chain on deck and put a semi-circular crack apoprox. 3" dia. Is there something I can use to seal this temporarily until I can get a permanent repair done.
Should be a fun one, since it's in the grey diamond pattern non-skid. :doh:
Jul 28, 2010
914
Boston Whaler Montauk New Orleans
Duct tape!! ;-) Seriously, I've found Marine Tex to be very good. It's like a 2 part epoxy putty. It is actually quite permanent, but can be sanded down and painted or glassed over. I love it. I've used it for a number of "drill & fill" projects. If you're really looking for temporary, how about a clear silicone sealant which should come off fairly easily when you do the permanent repair?
Ross
Jun 15, 2004
14,693
Please stay away from silicones on a boat they leave a residue that is practically forever and nothing with adhere to it. There are seasonal caulks made for houses. You can apply them as winter approaches to seal windows and peel them off in the spring.
OldCat
Jul 26, 2005
728
Catalina , Nacra 5.8, Laser, Hobie Hawk Wonmop, CO
If is just a crack - how about penetrating epoxy? Marine Tex is OK too, but expensive & doesn't flow well into a small crack. Maybe it depends upon how wide the crack is? Also, Marine Tex will yellow over time unless covered by paint or gelcoat - and epoxy breaks down over time in the sun. Probably none of that matters if you are going for a temporary repair & going to grind out later. If the crack is too big for penetrating epoxy & you are going to grind it out in a few months, regular epoxy should work & be cheaper than Marine Tex.
Best o' Luck,
OC
tich tor ang tesmur
Jul 28, 2010
914
Old Cat, Marine Tex is expensive, but was recommended, and I used it. Are there other similar products you would recommend? Always looking to save a few $$$.
The Capt. Tulleys looks interesting, especially for spider cracks. Steve, have you used it? How'd it do?
zeehag
Mar 26, 2009
3,198
i didnt like cpt tolleys for wood -teak- repairs--cracks the wood more.... but used on fiberglass was good---
Sep 20, 2006
2,955
Capt. Tolleys looks good, can it be removed enough to do a permanent repair and compatible with Gelcoat?
Wasn't going to use silicone, but did think of household caulking, i.e. mono or something like that just to seal it from water for now.
Ross
Jun 15, 2004
14,693
ScottB, some of the modern caulks are superb. You can get an idea of the quality by the guaranteed life on the tubes.(the guarantee is worthless). I use an acrylic/urethane caulk that is water clean-up when fresh and extraordinary when cured. Is labeled for fifty year useful life and I am inclined to believe them. Look in one of your better paint stores.
Feb 6, 1998
11,772
Scott,
1- The fact that the crazing is in a circular pattern is normally indicative of a void between the gelcoat and the substrate and the gelcoat caving in on it causing the crazed ring. This is not uncommon in hand laid hulls. Anyone who has worked in a mold will know how easy it is to roll some glass and have it lift as the roller passes over it just enough to cause a void. On our brand new 2005 Catalina I had about seven of these voids that I found and were fixed before commissioning. Because many boat owners don't realize how important it is to survey a new boat these voids are often not caught until a crazed ring shows up or the boat is for sale and the surveyor finds them. This is where the resin infusion methods for building boats really shine! Voids on resin infused boats are nearly non-existent.
2- Sound out the area with a small brass or phenolic hammer and listen for changes in tone. You will likely sound a different tone inside the crazed circle.
3- If the soundings indicate a void it needs to be injected. If the void seems deep from the sounding you can slightly thicken the epoxy with some cabosil. If it is not very deep un-thickened resin and a syringe (West System sells them) will work fine.
4- It is unlikely that the gelcoat crazing continues into the substrate so it is mostly cosmetic. Crazing in the gelcoat will not normally let in much if any moisture content to the underlying laminate. I have had my meter on many crazed ares, Cape Dory is FAMOUS for crazed decks, and the readings over crazing are no higher than non-crazed dry areas.
5- Fixing the crazing can often make it look worse so consider a pro or just living with it.
Fixing Yourself
1-You would need to cut a v-groove following the craze lines with a Dremel. This opens it up and gives the gelcoat tooth and prevents it from re-appearing. It is important that the edges are beveled and have a gradual taper to them.
2- You would want accurate color matched gelcoat in both waxed and un-waxed or some PVA in a spray bottle.
3- Route the groove and fill with slightly cabosil thickend non-waxed gelacoat to near full but not full.
4- Lay on a thick layer of waxed gelcoat to a thickness higher than the diamond pattern.
5- Use a set of jewlers files, chisels and sanding blocks to re-create the diamond pattern. This will work significantly better than the method where you make a mold but is tedious.
6- This is done AFTER you have done the injection to repair any void that may be there so don't forget to put a dab of gelcoat over the small injection hole. Usually two holes and a 1/8" bit is sufficient for a small void.
Unless you suspect the underlying lamination is compromised I would not bother with thinned epoxy, caulkings or other band aids as there is little chance of further damage. If it is a void I would address it so water can't become trapped between and "pop" the gel in a freeze..
